 servo plug >
servo plug
servo plug
Old 04-10-2009 | 04:18 PM
wzak29's Avatar
Default servo plug
I have a Airtronics radio system (vg400) the servos have 3 wires, center red with black and blue I can plug the servos into the receiver in both directions what is correct black facing outside or blue?
Old 04-10-2009 | 04:27 PM
Default RE: servo plug
Plug it in one way or the other. If it works-you were correct. If it doesn't work-no harm done. Just flip it. It will NOT damage anything to have it reversed.
Not the preferred way I know but functional.
Old 04-10-2009 | 06:03 PM
CGRetired's Avatar
Airtronics receivers are keyed so that the servos will only go in one way. The plug looks like the one in the sketch.
Old 04-10-2009 | 06:42 PM
wzak29's Avatar
THESE ARE THE NEW "Z" conectors and go either way
Old 04-10-2009 | 08:55 PM
JohnBuckner's Avatar
Airtronics Z, Hitec S and Jr are keyed by those tiny bevels however they can be easily plugged in backwards. Another simple method is to just remember all the majors which use a topside plug orient the ground (Black lead) toward the outside of the case. Never have to stare at those tiny bevels agine.
John
