upload
Old 04-11-2009 | 04:21 AM
wzak29's Avatar
Default upload
When I click on new post and try to upload a photo I get this message It only takes me about 20 seconds to do it, the photo is a JPEG and 53kb in size?
We are sorry...
You are seeing this message because of one of the following reasons:
Your session timed out.
The server was restarted before you made a HTTP POST (posting a message, registering an account, login, etc.)
Problem #1:
You probably spent too much time and your session timed out. This is, however, rarely the cause of the problem because we implemented a session keep-alive mechanism to prevent this issue from happening. However, the server itself could have experienced some problems that prevented this mechanism to work as it should, and therefore we cannot completely rule out the possibility of this either.
You need to make sure your browser has cookies enabled. See below for instructions:
Netscape Communicator 4+:
Select "Edit" from the browser Menu bar
Select "Preferences"
Double click on "Advanced"
Verify that "Accept only cookies that get sent back to the originating server" is selected
Select the "OK" button
Microsoft Internet Explorer 4+:
Select "View" from the browser Menu bar
Select "Internet Options"
Select "Security" tab
Select "Custom (for expert users)" security level and select the "Settings" button
Locate "Cookies" and verify that "Allow per-session cookies (not stored)" is enabled
Select the "OK" button on the "Security" window
Select the "OK" button on the "Internet Options" window
If you already have cookies enabled and still experienced the problem, see problem #2 below for other possible causes.
Problem #2:
Your server experienced problems and was forced to restart. Restarting a server will erase all session data and our protective mechansim had no choice but to drop your HTTP POST because we had no way to identify you without valid session data.
Many forum administrators host their forums on shared servers, on which could have more than 200 sites hosted together. Sometimes the server has to be restarted because some badly written programs on other sites may drain the CPU/RAM and cause the IIS to restart itself. This is unfortunately an inevitable situation that many site administrators and its users have to face from time to time.
Technical Information
For more information, please contact forum admin.
Old 04-11-2009 | 05:30 AM
wzak29's Avatar
Default RE: upload
This is what happening click (new post) click (click here to upload images) a box opens “select a file to upload†click (browse) find photo then click (ok) message “file uploaded successfully†click (ok) at bottom you have (ok) (preview) (cancel) click (preview) blank window opens click (ok) get error message. Internet explore, cookies enabled, photo jpeg/53kb
Old 04-11-2009 | 07:57 AM
Default RE: upload
just a test to see if I have the same problem... It appears that I do not...??? How long does it take for your upload..Perhaps you have a slow network and it times out? Rich
p.s. one thing different was that I was REPLYING to your post...you were creating a brand NEW post??? RG
Old 04-11-2009 | 08:01 AM
Default RE: upload
Did you see and use the warning on the bottom of the reply page???
it says..... (for image uploads click reply or quote icons in any post above)
Old 04-11-2009 | 08:07 AM
wzak29's Avatar
Default RE: upload
I want to start a new post not a reply
Old 04-11-2009 | 08:12 AM
wzak29's Avatar
Default RE: upload
my first build a G.P. PT-40 MKII
Old 04-11-2009 | 08:14 AM
carrellh's Avatar
Default RE: upload
I did a test and didn't have an issue
http://www.rcuniverse.com/forum/fb.asp?m=8670214
From the time I clicked 'new post' until I clicked OK to submit it was about a minute.
I do get the 'time out' screen once in a while. I usually type everything in notepad and make sure I know exactly where the pictures are. That way I can click 'new post,' paste my text, and upload images as fast as possible.
Old 04-11-2009 | 08:16 AM
Default RE: upload
wzak Looks like you've got it figured out! Congratulations...Rich
Old 04-11-2009 | 08:18 AM
carrellh's Avatar
Default RE: upload
ORIGINAL: wzak29
I like the PT series. Looks like you did a nice job on it.
Something else I have done regarding new posts. Write my text in notepad. Click new post, paste, submit. Then 'edit' the post and upload the phtotos into it.
Default RE: upload
wzak29, did you type a message into the reply box or just try to upload photos? I believe you have to type something as well as upload photos. I don't think you can just upload photos without typing anything.
Beautiful PT-40, can not tell by looking at the finished plane that it is your first build, you did an incredible job.
Old 04-11-2009 | 08:21 AM
Default RE: upload
My PT-40. wzak29, I actually like your simple design better than my first covering job shown here.
ID:	1177710   Click image for larger version
