Hooking up >
Hooking up
Hooking up
Old 06-17-2003 | 04:59 PM
Default Hooking up
I have just built a Sig LT40, I have the servos in and need to know how to hook it all up. I got a Futaba on off switch with a charging jack. What goes where? Does the red one go to the receiver? I also have a Futaba 9CAP (Aircraft), what do I need to do to get it up and running to test the servos? Thanks in advance
Old 06-17-2003 | 05:28 PM
RCaeroguy's Avatar
Default Hooking up
You can either take it to your LHS or find an experienced modeler in your area to help you out.
Old 06-17-2003 | 05:59 PM
My Feedback: (17)
Default Hooking up
Iams'
take a look at your radio manual, it should have all the 'assignments' as far as what goes where in the rx. Good luck,,,
How do you plan on setting up your aileron servos to the rx? How many servos service the ailerons?
Old 06-17-2003 | 06:37 PM
Default Hooking up
Iamsignal3,
Where do you fly?
Do you belong to a club?
Taking it into the local hobby shop is a good idea.
I am in Commerce Twp and am willing to help if you need it.
I use Hitec equipment but I can get you going if you like.
PM me.
Bill
Old 06-18-2003 | 12:41 AM
Default Switch
I have all the servos in and the plane is basically done. I just am having a hard time with that switch. FUTABA (bless their hearts) do not put any instructions on their stuff. Just need to know about that red connector. Is that the charging jack or does that plug into the b slot on the recv. The book was great help with the assignments, but belly up on switches.
Thanks for your posts
Thank you for the offer RedWing. I am really new to this and could use some help when I decide to try to fly this thing in a couple of weeks. Right now I am trying to work out most of the kinks myself as part of the learning curve, but am not going to fly without help
Old 06-18-2003 | 12:49 AM
Default Missed
I have the servos set up per the Futaba manual, the ailerons are on one servo rcv channel 1, and are a push, pull.
Old 06-18-2003 | 01:33 AM
MinnFlyer's Avatar
Default Hooking up
The red one goes into the reciever.
Old 06-18-2003 | 01:40 AM
Default Hooking up
I was waiting for you to help MinnFlyer.
