balance point for Tigre 60
Had a mishap and need to balance my Tigre 60. Anyone know how far back on the wing the CG is suppose to be. I can't find the stupid plans. Thanks
RE: balance point for Tigre 60
Irish.. you may be able to download the plans from their web site or perhaps from Tower Hobbies if you search on Tiger 60, it may have a link to the manual.
Better yet.. here's the link.
http://manuals.hobbico.com/gbg/gbga0068-manual.pdf
CGr.
CGr.
ORIGINAL: goirish
If you balance the model with a CG is at 25% of the MAC of your model and a mishap does happen, then you can be assured that said mishap was NOT a fault of the CG. Look elsewhere!
Within the conditions as stated in the first sentence of my post, you can be between 20 and 28% and the model will fly very safely as far as the CG is concerned. After a bit you can adjust farther aft if you so desire. How far back depends on your bravery. Aft of 35% will test your skills.
