 help with first ARF >
help with first ARF
help with first ARF
Old 05-10-2009 | 07:54 PM
Default help with first ARF
hey guys, i have a tower trainer 40 that i just picked up, the wing joiner did not fit well out of the box, and now ive sanded it so much its no good. any one know the size plywood its made of and the angle of the cut?
Old 05-10-2009 | 08:16 PM
Alex7403's Avatar
Default RE: help with first ARF
From the manual
angle = arcTan(4-14 / 31) = 7.8 deg,
7.8 deg is a lot, 5 deg will do as well, the important part would be if the wings sheeting are in contact with each other.
now not must but very helpful, i like to fiberglass with epoxy all of my wings center.
hope it helps
Alex
Old 05-10-2009 | 08:18 PM
ChuckW's Avatar
I'm sure someone on here has this plane unassembled and can give you the dimensions of the joiner to make your own. Another option is to call Hobby Services: 217-398-0007. This is the support/repair branch of Hobbico (Tower, Great Planes, Futaba, etc.). They are always very helpful and will likely be able to help you in acquiring a new joiner..
Old 05-10-2009 | 11:06 PM
yeah, the hinges that came with this plane are giving me a run for my money, they frayed and now i cant get them in. ARGHHHHHHHH
Old 05-10-2009 | 11:23 PM
ChuckW's Avatar
ORIGINAL: evilhorse
Try cleaning the slots out with an X-acto. If that doesn't help you can usually get CA hinges at the hobby shop. The GP and Sig hinges seem to both work really well.
Old 05-10-2009 | 11:26 PM
i did clean them, but the hinges frayed, im calling tower tomorrow about the wing joiner, ill order a bag of hinges while im at it.
Old 05-11-2009 | 10:26 AM
Hello Evil
I have put together two Tower Trainer .46's, Had a mid-air collision on one, and recently finished my ARF. Unfortunately, I do not have the dimensions for you, but I do agree that the hinges are TERRIBLE. All mine frayed even after extensive clearing of the hinge slots, I went to my local hobby shop and picked up some after market hinges that were very tough and went in like a hot knife through butter. I believe they were Great Planes hinges, white in color. Only a few bucks for a pack of 20 or something like that. I would call Hobbico and have them send you a replacemet joiner, easiest way to deal with it. Oh and dont forget to epoxy the wings together, i forgot that step and had to buy some extra straps. Although im sure it will be fine and it has 4 flights on it now with the current setup. Enjoy, its a great flying machine.
Ed
Old 05-12-2009 | 12:29 PM
forestroke's Avatar
why not just epoxy the crap out of the wing joiner. so it's a little small, i tihnk the epoxy will be enough. as for the CA hinges, just cut a little off. as long as it's not a lot, i think you can do with a slightly smaller hinge.
my two cents.
Old 05-12-2009 | 12:30 PM
forestroke's Avatar
just make sure you use good hinges on the elevator. if you lose that you lose the plane!
Old 05-12-2009 | 09:30 PM
Tower is awesome, i have a new wing joiner on the way and hinges free, i bought the GP Hinges and like Erusso said, hot knife through butter.
