 Storage Temperature? >
Old 05-10-2009 | 10:36 PM
OkadaKeisuke's Avatar
Default Storage Temperature?
Hey guys,
Strange question for you all.
I understand that storeing your planes in heat can damage them (correct?), but can storing your planes in a REALLY cold shed damage a plane?
I don't have much room to store planes and was wondering If I could build a shed to store any planes that I may aquire down the road. The only problem I can think of is winter.[sm=48_48.gif] And here in Maine it can get really cold.
It is coming up on summer now (high temps of 68 past week or two) and if I am going to build a shed it would be this summer. So I thought I'd ask for some opinions on the matter before winter rolls around again.
Thanks guys.
Noah
Old 05-11-2009 | 05:31 AM
bingo field's Avatar
Default RE: Storage Temperature?
I store all my stuff in my unheated shop, for years now. I just go out and put the batteries on charge once a week, cycle them once or twice during the winter. It hasn't affected my fuel, or any of my guns or ammunition. The thing I would think about would be some ventilation, to keep moisture from building up, that would affect the wood some, and if you have any unsealed fuel, could cause a moisture problem in it. My shop is a 24x20 frame with metal covering type structure. I also keep a lot of computer stuff out there, switches, routers, parts, printers and whatever.
Old 05-11-2009 | 09:28 AM
Minnreefer's Avatar
One of the bad things about cold is it makes covering very brittle, but if you don't touch it, then it won't be a problem in the cold.
Jon
Old 05-11-2009 | 12:31 PM
My Feedback: (-1)
When I lived in the mountains of Calif. I kept all my planes and modeling stuff in my shed, I did have air vents in there as mentioned, don't know if it helped or not but notheing ever warped or went bad. The shop I have now only goes down into the 30s and up to about 90 plus we really have no moisture problem here so everything is OK here too.
Old 05-11-2009 | 01:37 PM
Great! I thought about ventilation and moisture, but wasn't sure if the cold would hurt any plane.
Thanks guys!
