 Throttle cut on DX-7 >
Old 06-03-2009 | 06:41 AM
goirish's Avatar
Default Throttle cut on DX-7
I know this has probably been answered a 100 times, BUT, I can't seem to locate it. I want to set up my DX-7 with a throttle cut. How do I do it. It is easy on my Futaba 7CAP. If you want just tell me to go fly a kite. I also don't see anything in the manual about programming this feature.
Old 06-03-2009 | 06:45 AM
Default RE: Throttle cut on DX-7
You're right, it's been covered before. Hope this helps.
Old 06-03-2009 | 06:50 AM
goirish's Avatar
I guess I am not very good using search.  Really don't know what to type for the search.  Yes it does help, at least I know it was covered.
Old 06-03-2009 | 06:51 AM
Had to go search for a minute but thought I'd tease you first. HEHE.
try this: http://www.rcaerobats.net/Spektrum/dx7_throttle.htm
Old 06-03-2009 | 06:56 AM
goirish's Avatar
Many thanks my Friend.
Old 06-03-2009 | 07:31 AM
Actually, you asked and received that same answer about 2 years ago. That's where I found it.
Old 06-03-2009 | 07:35 AM
goirish's Avatar
Well when we get older, our memory starts to fade or wane.  I think mine went out.  I have had my DX-7 for almost 2 years and have never used it until I flew a vapor bind and fly with it a few months ago.  I now have it installed in my 1/4 scale cub with a gas 26.  I really appreciate your help again as usual.
Old 06-03-2009 | 01:23 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
ORIGINAL: goirish
What was the question???
Ken
Old 06-03-2009 | 01:34 PM
There was a question?[sm=bananahead.gif]
Old 06-03-2009 | 01:48 PM
goirish's Avatar
Who asked a question??????-[8D]
Old 06-03-2009 | 02:27 PM
Minnreefer's Avatar
Go fly a kite
Old 06-03-2009 | 03:10 PM
N429EM's Avatar
Page 37 of your DX-7 manual explains "Throttle Recovery".
When you set up your throttle trim, allow enough down throttle trim to kill the engine.
Then, when flying, holding down the throttle trim switch will run the throttle servo all the way closed.
When ready to restart your plane, click the throtttle trim up once, and the servo will be set to your idle position.
Basically, this is the operation they use for throttle cut.
Works for me.
EJ
