 prop for a 46AX >
prop for a 46AX
prop for a 46AX
Old 06-08-2009 | 10:04 AM
Default prop for a 46AX
Ihave a 46ax that Ihave a mas 11-6 on, I'm wanting a good prop for hovering. Iwas thinking about a apc12-4 or 5. what do you guys think? what is a good prop for this engine for 3D flying?
Old 06-08-2009 | 10:06 AM
MinnFlyer's Avatar
Default RE: prop for a 46AX
12x4
Old 06-08-2009 | 10:10 AM
brett65's Avatar
My Feedback: (18)
I like my 12x4, but the 12.25x3.75 is a wicked beast! My trainer would almost hover with it. It depends on the plane though too, but you will have the best results with the big low pitch props.
Old 06-08-2009 | 10:14 AM
thanks guys. i'm going to pick one up later today.
Old 06-08-2009 | 10:29 AM
ChuckW's Avatar
Iagree with Brett. 12.25x3.75 APC. Great prop for that engine.
Old 06-08-2009 | 04:42 PM
microsprint9's Avatar
I find the APC 12x4 spools up a bit quicker than the APC 12.25x3.75 and the little thrust that is lost is worth it to me.
Old 06-08-2009 | 04:53 PM
12.25x3.75 APC.  I use one on my Magic with a .46fx.  It hovers nice, and has enough to pull out.  I say try them both (12x4) and see which one suits you, and your aircraft better.  </p>
Old 06-09-2009 | 09:30 AM
hugger-4641's Avatar
+1 for the 12.25 X 3.75. I've run it and a 12x4 on my Somethin Extra /.46ax. This plane is a little heavy for a .46 and won't hardly hover with the 12x4, but it willwith the 12.25 X 3.75.
Old 06-09-2009 | 11:44 PM
jib
12x4 rocks on my TT PRO 46 on a 4.5 pound plane.
Jack
Old 06-10-2009 | 09:22 AM
I swing an 11 X 6 on my .46 FX, love that combo.
Good luck.</p>
Old 06-10-2009 | 11:11 AM
Deadeye's Avatar
Am I the only guy who mounted an APC 14X4 on mine? I love that combo.
Old 06-10-2009 | 11:27 AM
CGRetired's Avatar
14X4!!!  Jeech..  </p>
Old 06-10-2009 | 01:46 PM
Bax
A 14 x 4 would be considered overly-large for the .46 AX.  What RPM are you running?  The engine will give its best performance if you prop it to run 12,500 RPM to 13,000 RPM when leaned to just rich of peak RPM on the ground.
Any propeller that will allow the engine to turn in that RPM range and fly your airplane as you desire is the "correct" propeller.
