Fuel metering device >
Old 06-21-2003 | 09:08 AM
rajul's Avatar
Moderator
My Feedback: (58)
Default Fuel metering device
I have a plane with a 16oz tank with a OS61FX and the running time on full tank exceeds 25-30 mins. When I want the cg to be more to the rear, and a shorter flight time, I normally pump fuel into an external 10oz bottle, then pump this amount into the tank. I am looking for an easier way to meter the fuel. Is there any device available that I can connect in-line with my electric fuel pump so that the volume of fuel pumped to the fuel tank can be monitored. Thanks for the inputs...........
Old 06-21-2003 | 09:43 AM
I understand what your saying but I'm not sure what the problem is, why dont you just shut the engine down via the throttle when youve had enough.
