Flying wing and DX7? Problem!
CA
<div>Ok so I just got my new mini speed wing bound with my Dx7 and I have run into a problem! I set the radio to delta and then when I go to reverse my ailerons becase they are reversed right now. When I do this it put the elevator on right in left on my stick and up and down is now ailerons. I am not sure how to fix this! If I switch the servos on my reaciver it does the same thang but with the evelator?
Any suggestions?
Andrew</div><! / message >
Any suggestions?
It's not the radio, there are just so many settings, menus and options available. I watch veterans fly through the functions while I befuddle my through relying on the manual as my guide. I had the exact same issue with a Delta wing configuration with a DX6. It all boiled down to me neglecting to read the manual and setting up the servo/receiver configuration "exactly" like the manual said. In the end it all worked out. It was really simple.
However, like you I was frustrated to no end and had to walk away from it and re-group. Take a break and do something else and take your mind off it. Come back fresh and start over.
