Engine from EBAY question >
Old 06-23-2003 | 06:31 PM
Default Engine from EBAY question
So I got a engine Fox .40RC Std, ball bearing engine off ebay. IT was supposed to be NIB...and it is excpet that I think it has been sitting for a LONG time. I tried to turn it over with my hand and it is really really stiff. Also, the throttle lever (or whatever it is called) is also pretty stiff. Any suggestions or should I hit this guy up for a refund? Thanks.
Old 06-23-2003 | 06:36 PM
Thats the bad thing about ebay.
Why not cook it in a crockpot full of anti-freeze? Did this last year and could not believe how clean the engines came out. Just remember to remove the seals and gaskets before hand. Then add a little 3 in1 oil to the engine afterwards should be good as new
Old 06-23-2003 | 07:07 PM
FLYBOY's Avatar
Don't worry about it, engines stiffen up. Dump some marvel mystery oil in it and work the carb slowly. Dump some in the exhaust port and down the carb and turn it over and work it in. It will loosen up to good as new in about 2 minutes. You don't have a problem.
Old 06-23-2003 | 08:04 PM
Live Wire's Avatar
Carb and choke cleaner in airesol can, works great then after run oil. Those old fox engines had to be broke in slow, good engine.
Old 06-23-2003 | 08:22 PM
Engines stored for a while frequently do that, it's just the oil getting gummy. The suggestions above will all work to loosen it up. You can also just mount the engine, go to the flying field, and use fuel to loosen it up. Then you are already primed and ready to go.
Old 06-23-2003 | 09:38 PM
Or just drop it in a jar full of fuel and leave it for a day or so.
Oh dont use the fuel in an engine, it'll be full of crud
