HS 82mg servo Buzzing
My Feedback: (13)
NJ
Ive recently decide to start using a fast micro servo on throttle. Only problem is that this servo buzzes ALOT. Ive even removed the linkage and arm and it will still buzz through the travel range when sitting still. Is this normal for micro servos or do I have a lemon? I would think this isnt normal but I just want to make sure.
Hitec HS 82mg
Hitec HS 82mg
looks like this is an analog servo..so it's not the digital buzz.....I saw that it was rated for 4.8 or 6 volts...you're not using 7.4 volt lipo or something like that are you? if not I'd say you might have a bad servo....can you go to your LHS and ask if they have heard of this servo buzzing...or maybe they'd try another one....
