 trainer help! >
trainer help!
trainer help!
Old 07-05-2009 | 11:00 PM
Default RE: trainer help!
just been out on got myself a big bag of #64 rubber bands. all set with them and also printed myself off a manuel as i bought it second hand and didnt have one. Tonight i will adjust the throws and check how good these new rubebr bands are.
What about battery and receiver installation. I have the ar7000 receiver (i think) the one that comes with the dx7. using a 6v nimh battery. Any hints/tips with these with installation and access for the aileron servo before flight......
So far the battery is velcro to the bottom with some spong stuff underneath it, the main receiver is rapped in foam and the small receiver is velcro to the side of the plan (inside ofcourse)
Old 07-06-2009 | 02:50 AM
Just been adjusting all of the throws. Here is a link as to what they should be.
http://www.theworldmodels.com/para/i...ion/html/A046/
Are the measurements from center to one side or from one side to the other. Eg. should the rudder move 20mm from center stick to one side, then another 20mm from the center to the other side giving me a total of 40mm movement?
Old 07-06-2009 | 07:50 AM
Moderator
You might check your manual on the reciever install. Some 2.4 recievers are heat sensitive and so shouldn't be wrapped.
Old 07-06-2009 | 09:13 AM
Lnewqban's Avatar
ORIGINAL: white pulsss
Yes, just like you have described it: measure from center to each side.
Sorry, I don't know about your receiver, here is a review:
http://www.flyrc.com/articles/spektrum_dx7.shtml
Old 07-06-2009 | 09:50 AM
Lnewqban's Avatar
Some more good reading for you:
http://www.masportaviator.com/fh_flighttech.asp
http://www.masportaviator.com/fh_prifly.asp
