60 size trainers
Can anyone recommend a 60 size trainer?
I'm fixing to build my trainer and I like the big is better theory. Plus I flew a long time ago and then I flew a .20 size plane and I want to step up a bit in size.
So far the only real trainer I've found in 60 size is the senior telemaster, any others?
Take a look at the PT-60 from Tower.
Also search here for my comedy on my Thunder Tiger TT60 Trainer
It is a great flying plane. Takes one 'ell of a BEATING !
something with 70-80" wingspan - Telemaster is huge like this, but a bit frail with it's construction = flies like a feather.
Borzak, you mentioned that you wanted to build, were you referring to a kit or an ARF?
If it be an ARF then I would like to suggest this plane right here.
The World Model Super Stunt 60. This plane would make an excellent trainer since it has such a Hugh wing it just floats in the air, any instructor can tech you in no time with this plane.
Super Stunt 60
Super Stunt 60
GA
a pt-60 is the best 60 sized trainer.........i was helping to train a guy on one of them.......it flys great for a beginer.........if you build it strait it will fly great.
