 large or small prop? >
Old 08-08-2009 | 04:32 PM
nubzorz's Avatar
Default large or small prop?
I just got a cheap cessna 747 it came with 2 props a large one and a smaller one which prop should I use for more power and speed?
Old 08-08-2009 | 04:53 PM
ChuckW's Avatar
Default RE: large or small prop?
A Cessna 747????
Generally smaller diameter/larger pitch will give more speed while larger diameter/lower pitch will provide more "pull". It's kind of like the difference between a Corvette in top gear on the open road and a truck in the lowest gear pulling a load up a hill. Both utilize the engine power in different ways to achieve different goals.
Old 08-08-2009 | 05:21 PM
nubzorz's Avatar
yea its a cessna 747 from bananahobby http://www.bananahobby.com/1783.html this things pretty cheap it doesnt have alot of power so i need all the power i can get
Old 08-09-2009 | 10:41 PM
KitBuilder's Avatar
Generally draggy designs use larger diameter lower pitch and cleaner designs use smaller diameter, higher pitch. Yours should do better with the smaller diameter larger pitch... but use both and experiement.
