 speed controllers >
speed controllers
speed controllers
Old 08-13-2009 | 03:31 PM
Default speed controllers
What is the difference between the GWS ICS-GS100 vs ICS-100 speed controllers? Will the GS100 work for the GWS DHC-2 Beaver plane?
Thanks.....
Old 08-13-2009 | 04:29 PM
opjose's Avatar
Default RE: speed controllers
Functionally they are no different.
You get at most 8A momentary output from that ESC, so assuming 9.6 volt packs...
9.6v x 8A = 76.8 watts.
Assuming you would want 100-110 watts per pound on that plane, the maximum weight of the plane should be four fifths of a pound.
Old 08-13-2009 | 04:30 PM
I think, but not sure, the GS has a "brake" feature. Can't speak on suitability issue.
Old 08-13-2009 | 04:37 PM
opjose's Avatar
Correct, that's about the only difference.
Old 08-13-2009 | 06:13 PM
Is there any benefit, or detriment, to the brake?
