OS Engine QUESTION >
OS Engine QUESTION
OS Engine QUESTION
Old 06-27-2003 | 04:16 AM
Default OS Engine QUESTION
Hi there,
I have a brand new os 50 engine that I tried to break in today.
The drive shaft came lose while the engine was running and fell off several feet away. now i think I am missing a part. there is a notch in the crank shaft and a notch in the drive shaft there is supposed to be a peice that goes in to lock the two together? what part do i need to order? would a new drive shaft have that piece? I hope I explained it good enough , thanks for your responces.
Old 06-27-2003 | 05:11 AM
It's called the Woodruff Key. look up the part number from Os site and order.
Old 06-27-2003 | 03:02 PM
MinnFlyer's Avatar
Or bring the engine to your local hardware or auto parts store and see if they have one.
Old 06-27-2003 | 05:55 PM
Spaceclam's Avatar
why did if fly off? did you not tighten the prop?
