OS Valve needle >
OS Valve needle
OS Valve needle
Old 06-27-2003 | 02:27 PM
Default OS Valve needle
I need the L shaped tool that goes into the valve needle to adjust the valve. it is for OS 50 sx. ?do you know where to get it
Old 06-27-2003 | 03:00 PM
MinnFlyer's Avatar
Usually a 2-56 size push rod wire is the right size. Just cut a piece as long as you need, and bend an "L" into it.
Old 06-27-2003 | 03:47 PM
FLYBOY's Avatar
There is a set screw that holds it in there if you missed it. As mike said, put it in and tighten the screw.
Old 06-27-2003 | 03:56 PM
L shaped tool? Sounds like an allen key to me....
