crash
NY
crash
Hi I crashed a ARROW semi-symmetrical Hangar 9 plane. I then repaired it but can't get the transmitter to work. When I turn engage the switch on the plane the servos move once but that's it. The transmitter will not move the servos at all! I charged everything up and connected all leads according to the manual. Can someone please help................................ZIP[]
RE: crash
Obviously, the transmitter was not damaged in the crash unless you threw it to the ground afterward. You need to tell us what kind of transmitter and reciever you have. From what you describe it sounds like you are getting some power to the reciever or the servo's wouldn't twitch. But you may have a loose connection, may have a dead or damaged the battery,may have knocked the crystal loose in the reciever if its a 72mh system, or you may damaged the reciever itself. I would start by making sure you have a good battery, and let us know what kind of radio system you have.
NY
RE: crash
OK the battery is new I replaced the one in the crash. The transmitter is a JR Sport S400 4 channel radio and the receiver is a JR Sport RS600 72/50MHZ. I hope that is enough info.
Zip
Zip
RE: crash
Pull the receiver out of the plane.
Remove and re-insert the crystal.
Connect a servo to it.
Turn on your TX
Connect a charged RX battery.
Try to move the servo.
If it moves, with the RX ON, move the servo lead to another channel.
Repeat to see of the RX passes the test.
If so, put the servo back on the first channel, and while moving the servo, tap the RX lightly on your table top.
Does it continue to work through the knocks?
If not replace it.
If so, you may have something amiss elswhere in the wiring of your plane, as it is unlikely to be the RX... ( assuming the antenna wire is good and undamaged. ).
Turn on your TX
If not replace it.
RCU Forum Manager/Admin
My Feedback: (9)
RE: crash
I agree with the others, it sounds like it's either the switch or the receiver. Even if it turns out the receiver still works it's still a good idea to have it sent in for service after the crash. There are a lot of fragile parts in a receiver such as this and the shock from the crash can cause damage that won't show until it's subjected to the vibration of a running engine. I always send in a receiver after a crash to have it serviced, trust me in that it's cheap insurance for the next plane you want to use that receiver in!!
Ken
Ken
OH
RE: crash
I had a receiver that was in a crash and it worked fine until I fired the engine up. The vibration from the engine proved the receiver was indeed damaged in the crash.
If you get it to work thoroughly test it before you fly along with a very good range check.
RCKens advice is probably best, send it in and have it checked out.
RE: crash
Or the transmitter could not transmitting due to a blown fuse? I've had that happen a few times, especially if the TX is turned on too soon after charging. I've started carrying spare fuses for my JR/Spektrum radio's.
You have to take the screws out of the back of the case, pull the battery crystal, and carefully remove the back. Then you'll be able to check the fuse to see if it's blown or not. Be careful when putting the case back together so you don't tighten the screws up too much and strip out the case.
Hogflyer
Hogflyer
CO
RE: crash
what caused the crash? I may be reaching here, but I've had the same issue when the RX battery is dead. the servos will jump when you first turn on the switch then they won't do anything.
EDIT: sorry I just re-read your post and see you did charge the battery. did you check the voltage?
RE: crash
Hey Zip! Check that old rx crystal That is likely your problem. Would be a shame to trash rx if only a bad crystal which can be replaced for couple bucks.
