Help!
got a exceed f-35 and exceed 6ch txmest up the stock file now i get no movement on cha. 1-2-3 just black lines.i'am on the right com port but do not know howe to use software new to this hobby! trying to get a mix setting. were if i move stick up Elevator and Ailerons will move up at the same time. Same with down.move stick side to side one side up other side down is there a member out there that has a STOCK file OR the same plane and TX as me that can send me the file? my [email protected] thanks SunSun.
I don't mean this in a negative way, I want to be helpful, so my advice would be to put that f-35 away for a while. You stated that you are new to the hobby. An EDF foam jet is nowhere near appropriate as a beginning airplane. There is a sticky post at the top of the beginner forum with a good list of trainer airplanes. If you want to stick with foam electrics, look at something like the Hobbyzone Super Cub. Trust me, it is a lot easier and less expensive in the long run to start out with the right airplane.
good point but not my first edf jet just my first ARF edf jet so tryed to set up mix mode and mest up! so on my PC whith software all i get is black lines on ch-1-2-3 need a good mix mode file or a stock one. Do you know of one or a link to one? exceed 6CH TX thanks</p>
