 How to reverse polarity on brushless motor >
Old 09-03-2009 | 07:55 PM
Default How to reverse polarity on brushless motor
So I am trying to reverse the polarity on my brushless motor. It has three wires so I am thinking that I should just switch the black and red while leaving the yellow alone. Is this correct?
Old 09-03-2009 | 08:12 PM
microsprint9's Avatar
Default RE: How to reverse polarity on brushless motor
If you mean reverse the rotation then yes, switch any two wires and it will run reverse.
Old 09-03-2009 | 08:13 PM
Why do you want to reverse polarity/ Is motor running in wrong dirction/ If that's the case then switching any 2 of the 3 wires will change it's direction. That doesn't reverse polarity but does do what you want .
