 Hitec Servo gear play >
Old 09-20-2009 | 12:58 AM
My Feedback: (13)
Default Hitec Servo gear play
Ive got slop in the gears of a Hitec 5625 which I use on a rudder. Is it ok to take apart and just rotate the gears? or should I be replacing them with new gears?
Old 09-20-2009 | 06:36 AM
Default RE: Hitec Servo gear play
Why not up grade tp a 5645.....not that much....and relieves you of the worry
Old 09-20-2009 | 09:48 AM
My Feedback: (-1)
Very good question, I have never given it any thought so never tried it. I have also never worn out the gear train but I have broken a lot of them so I have always just replaced them, cheap and only takes a few minutes. Why don't you give it a try and post up your results?
Old 09-20-2009 | 04:34 PM
My Feedback: (13)
I think I will give it a shot. Ill save the $50 bucks spent on a new servo for a new plane instead!
I will post results.
Old 09-20-2009 | 09:11 PM
My Feedback: (-1)
Unless it's a standard servo that cost under about 12 bucks it's better to replace the gears.
