 hinge help >
hinge help
hinge help
Old 09-24-2009 | 08:22 AM
Default hinge help
Is there a tool to cut slots for hinges..... or is there a way to easily cut them.......
Old 09-24-2009 | 08:50 AM
My Feedback: (17)
Default RE: hinge help
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXK263&P=0]CLICK ME !!!!!!!!!!!![/link]
Old 09-24-2009 | 09:14 AM
someone said something about a tool that looked like a double headed exacto knife..... but couldnt find one....
Old 09-24-2009 | 09:15 AM
Charlie P.'s Avatar
I made mine out of an old hacksaw blade. One end is sharpened round and the other is a "V" shape. For CA hinges just press it into the balsa. Start with the round end and square it up with the "V" end.
For larger hinges I work the opening with the nibbler tool shown - a few bucks from Great Planes.
ID:	1281124   Click image for larger version
Old 09-24-2009 | 09:25 AM
Charlie P.'s Avatar
Here's a link to the X-acto version.
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXE229&P=7]Hinge Tool [click me][/link]
Old 09-24-2009 | 10:39 AM
And here is a short video with some good techniques for installing CA hinges.
http://www.youtube.com/watch?v=nCNjg5HkPFw
Old 09-24-2009 | 11:23 AM
mclina's Avatar
ORIGINAL: Charlie P.
I have a set just like this, except each cutter has a red handle attached. I think it is a Great Planes product. I won it in a raffle. Prior to that, I was just cutting slots with an exacto knife.
They have worked fine for me. Not as easy as the motorized tool, of course, but better than free-handing it with an Exacto.
Edit:
My mistake. It is also a Dubro set, just with handles included for an extra $6.
http://www3.towerhobbies.com/cgi-bin...?&I=LXE230&P=0
Old 09-24-2009 | 11:58 AM
Here is another one:
http://www.harryhigley.com/Tools1.htm Scroll down to the bottom of the page.
This is the same one, but the picture doesn't help much,
http://www3.towerhobbies.com/cgi-bin...?&I=LXCLS2&P=7
Old 09-24-2009 | 12:29 PM
mclina's Avatar
ORIGINAL: crossman
I did buy this tool when I was building my first kit. I didn't find it any easier or more accurate than freehanding with an Exacto.
I do have the covering film trimmer from the Harry Higley website. It works OK, but I usually can get pretty straight lines with just a sharp razor blade.
That wing bolt drill guide has me puzzled. Is it really that hard to drill and tap wing bolts that you need a special jig for it?
Old 09-25-2009 | 08:20 PM
Charlie P.'s Avatar
If you don't get the hole perpendicular it will lift one side of the nylon wing bolt's head each time it's tightened down. This does two things: it will deform the balsa, or, if a plywood plate is in the wing, will eventually weaken the bolt to the point where the head seperates . . . followed shortly thereafter by the wing.
It's kind of hard to "eyeball" the angle freehand. I have a set of the Higley drill guides and they do help a lot in keeping the holes perpendicular to the surface.
