 Need suggestions on good floats >
Old 09-27-2009 | 01:44 PM
cappaj1's Avatar
Default Need suggestions on good floats
I'm looking for advice on what floats would be good to mount on my LT-40 in order to both fly it off snow this December and off water after that. I'm hoping to spend less than $75 and want some kind of rudder control built in for the water.
I'm thinking of upgrading the 46AX engine to a used 70 or 80 size four stroke to give it some extra torque on take off as well.
Any suggestions or tips would be appreciated.
Old 09-27-2009 | 01:51 PM
brett65's Avatar
My Feedback: (18)
Default RE: Need suggestions on good floats
This is what I got, they are easy to set up and the rudder works great. http://www.valleyviewrc.com/New%20Ba...s%20Floats.htm I put them on my trainer.
Here is a video of my plane.
[youtube]http://www.youtube.com/watch?v=Z9t3-mgryhs[/youtube]
Old 09-27-2009 | 02:24 PM
cappaj1's Avatar
ORIGINAL: brett65
Thanks, brett65,
Those look really good. I wonder how they'd be off snow? Any idea?
Old 09-27-2009 | 07:47 PM
brett65's Avatar
My Feedback: (18)
ORIGINAL: cappaj1
ORIGINAL: brett65
Thanks, brett65,
I have no idea about snow, but they're great on the H2O. I know floats are fine for any snow, but ski's work good on packed snow, or so I've heard.
Old 09-27-2009 | 09:23 PM
beau0090_99's Avatar
I had good success building my own this year, but if I was to try to shortcut it a little bit, I would check out either http://www.seaplanesupply.com/ or http://www.geocities.com/planefunfloats/ As for hardware I would pick up an Ernst Water Rudder kit from the LHS or other places, and make your brackets using 1/8" aluminum bar stock from HomeDepot or Lowes. (I used 3/4" width for a 36 size and would recommend the same for you).
If you are interested in scratching your own PM me and I can fill you in on how I did mine out of pink foam, Spruce, balsa sheeting and fiberglass.
Best Regards,
Curtis
