 Enya .15 model 3304 >
Enya .15 model 3304
Enya .15 model 3304
Old 10-01-2009 | 03:05 PM
Default Enya .15 model 3304
Hi all, I have an Enya .15 model 3304 glow engine. I am not that familiar with the hobby just started this year. I also have a trainer with an Evolution engine which I have flown etc. Well my question is this. The trainer engine has a connection for a fuel line that comes from the fuel tank and connects at or near the carburetor, another line connects at the muffler and returns to the fuel tank. On the Enya there is only one fuel line near the carb. there is no return line connection that I can see so what do I do with the return line on the fuel tank? Am I missing something? I am stumped, can someone help?
Thank You [sm=spinnyeyes.gif]
Old 10-01-2009 | 05:53 PM
Default RE: Enya .15 model 3304
Just leavethe "return line"open to air and place the end of this vent tube somewhere higher than the top level of the fuel tank.
Old 10-01-2009 | 06:52 PM
Thanks very much
Zip
Old 10-01-2009 | 10:01 PM
downunder's Avatar
The Enya doesn't use muffler pressure like your other engine because the carb is small enough not to need it so just do as was said earlier about leaving that line from the tank open and hanging in the breeze . There's a swivelling flap on the side of the muffler which was used to give a small shot of fuel straight into the exhaust port for priming but that's not necessary so keep it closed all the time or it'll be a bit loud.
Your engine is either a 15-IV or a 15-V, for some reason they didn't change the model number for the later engine. Now for the important bit . Don't use normal RC fuel in the Enya or it won't last long. It has a cast iron piston which needs at least 20% oil and preferably all castor. Personally I'd use 25% all castor fuel. With the right fuel these are very tough engines and will last just about forever.
Old 10-01-2009 | 11:50 PM
Thank you very much
zip
