 Vmar Apache II HELP >
Vmar Apache II HELP
Vmar Apache II HELP
Old 10-02-2009 | 10:58 AM
Default Vmar Apache II HELP
&lt;meta http-equiv="Content-Type" content="text/html; charset=utf-8">&lt;meta name="ProgId" content="Word.Document">&lt;meta name="Generator" content="Microsoft Word 12">&lt;meta name="Originator" content="Microsoft Word 12">&lt;link rel="File-List" href="file:///C:\DOCUME~1\RICHAR~1.TIM\LOCALS~1\Temp\msohtmlclip 1\01\clip_filelist.xml" />&lt;link rel="themeData" href="file:///C:\DOCUME~1\RICHAR~1.TIM\LOCALS~1\Temp\msohtmlclip 1\01\clip_themedata.thmx" />&lt;link rel="colorSchemeMapping" href="file:///C:\DOCUME~1\RICHAR~1.TIM\LOCALS~1\Temp\msohtmlclip 1\01\clip_colorschememapping.xml" /><xml><w:worddocument><w:view></w:view></w:worddocument><span serif="" roman="" new="" times="" style="">Currently have a Vmar Apache II trainer with a SC .46 glow engine.<span style=""> </span>The hull and wings are getting a bit tatty and I have a bad feeling in the next few days I am going to crash lol.<o></o></span><span serif="" roman="" new="" times="" style=""><o>
</o></span></xml><p class="MsoNormal"><span serif="" roman="" new="" times="" style="">I need some help.<span style=""> </span>Can someone point me in right direction of were I can get new wings and a hull from.<span style=""> </span>I don&rsquo;t mind if it is a different plane I want to use the same components for the Vmar<o></o></span><span serif="" roman="" new="" times="" style=""><o>
</o></span></p><p class="MsoNormal"><span serif="" roman="" new="" times="" style="">Thanks<o></o></span></p></meta&gt;</meta&gt;</meta&gt;</meta&gt;
Old 10-02-2009 | 01:04 PM
JohnBuckner's Avatar
Default RE: Vmar Apache II HELP
I beleve that airplane to be a pretty genaric forty sized trainer and its likely you can use your radio components and engine in lots of replacement trainers.
Exactly what is your radio model and do you have all the airborn components? And of course are they functional?
Also exactly what is your engine make and model?
John
Old 10-02-2009 | 06:53 PM
bingo field's Avatar
Why not refurbish it? A little glue, a small amount of wood to reinforce things, and some new covering, must be cheaper than a whole new plane?
Old 10-02-2009 | 09:14 PM
BOre
Too little information without which more specific recomendations cannot be made as you see.
