 maiden flight.... >
maiden flight....
maiden flight....
Old 11-27-2009 | 01:14 PM
Default maiden flight....
well it was a ok afternoon decided to hit the field for a flight or two took my moded bee gee sea hawk with a used 35 os motor made the plane a tail dragger just to see if i could worked real well made several flight about 3 tanks worth just need to make a aileron wing for it and it will be a great flyer ..could use some marking the all yellow sceam is a little hard to adjust to lol
Old 11-27-2009 | 01:20 PM
Default RE: maiden flight....
oh some pics would help lol
ID:	1321547   Click image for larger version
ID:	1321548   Click image for larger version
Old 11-27-2009 | 02:30 PM
CGRetired's Avatar
Kenn.. I hate to be harsh, but could you possibly add a little punctuation to your post? It makes no sense the way it is. If you want someone to read it, try to make some complete sentences, adding periods, and so on.
Thanks.
CGr.
Old 11-27-2009 | 04:10 PM
hudmun's Avatar
Sometimes i write my message in a email so i can use the spell check then copy and paste in rcu but it dosnt help with punctuation i guess you could write the message in word then copy and paste in the rcu message. [sm=49_49.gif]
Old 11-27-2009 | 07:28 PM
well it was a ok afternoon. decided to hit the field for a flight or two. Took my moded bee gee sea hawk with a used 35 os motor .Made the plane a tail dragger just to see if i could. Worked real well made several flight about 3 tanks worth. Just need to make a aileron wing for it and it will be a great flyer ..could use some marking the all yellow sceam is a little hard to adjust to lol
Any ideas on a good lookin sceam for this ??
thanks guys
Old 11-27-2009 | 07:30 PM
wow just realized how fuzzy the pics are sorry all.. cheap walmart cam will try to get better ones tonight
Old 11-28-2009 | 07:24 PM
ORIGINAL: kenncarleton
thanks guys
simplest thing to do would be to cover the top of the wing blue just like the tail???.....leave the bottom yellow and just run two black stripes, 4" wide, on the bottom of the main wing, run them from front to back 2"-3" from the outside edge of the wing tips......let us know how the aileron wing goes???....
__________________________________________________ ________
SIG E-FORCE 3D ELECTRIC>>>HI-MAX 2808-0980KV MOTOR>>>CASTLE CREATIONS PHEONIX 10 ESC>>>HI-TEC ELECTRON 6 DUAL-CONVERSION RECIEVER>>>ELECTRIFLY 11.1V 3S 15C 910MAH BATTERY>>>FUTABA 6EX FSST 2.4 GHZ. 6-CHANNEL COMPUTER RADIO>>>15oz. ALL-UP WIEGHT WITH BATTERY
Old 11-28-2009 | 08:17 PM
the tail was blue when i got it i got it used.. i think i will go to the lhs (local HAHA it 120 miles away lol ) and see if i can match the blue the black is a good idea thou thanks
Old 11-30-2009 | 08:42 PM
look's really good to me and don't feel bad, my LHS is exactly 2 hour's away too.....i buy all of my stuff on e-bay, or better known to some as "fee-bay"......i don't pay much attention to the politic's, because with e-bay the seller pay's the fee's, not the buyer(me).....you know you can get most of those wrinkles out of that plane with a RC covering iron, or you can use a regular clothes iron and a wash towel......get the clothes iron hot and lay the wash towel over covering to prevent burning the covering.....start with medium hot, then turn the heat up slowly until you obtain the proper temperature.....i have a covering iron now, but back when i first started out, i didn't own enough planes to warrant spending the extra money, so i just used the wifey's clothes iron when she was at work.....ha! ha! ha!......if you do decide to finish the rest of the plane, it should look something like this(see pictures)......this little red and white trainer was one of my first planes, i'm pretty sure it was a SIG LT "something????.....kinda small with a o.s. 25fp, flew like a son of a b***ch, classic SIG quality for you.......i still have the motor on a "HOUSE of BALSA"-"GAS STIK 10"......10 size "stik" with an o.s. 25fp, flies hot, but what a freakin' blast, it's a "STIK" and it will do anything you want it to.....plus it keep's me young, if you know what i mean???.....bad thing is, i need to swallow a whole six-pak of "coronas" when i get home to get my hand's to stop trembling......ha! ha! ha!.....you know you could go over that blue with some bright red and then use some black for trim......black checkers, about 1" square, layed out in an angle at the wing tip's......hang on, let me go take a couple of pick's of my airplane trim schemes.....the yellow one is a "ACCEL HOBBIES-KATANA 30E" electric, this is what i mean when i say to lay checker's at an angle, at the wings tip's.....i drew and cut the flames, freehand and the numbers 22, too......i played with the shape of the number 22, to follow the angle of the checker's, kinda look's like nascar race car's.....you could also go with the trim scheme on the trainer since it more resembles your plane......one sheet each of self-stick red and white should be plenty......i think red and black self-stick should go right over the old blue and should really set it off in the air......i included one picture of self-stick checker's, but i think the bigger 1" squares would look better.....a little more work to cut them out by hand, but well worth the effort.....i used the "fonts" program on my windows/computer to find the right shape of number "22" and then i printed it out, scanned it with the same printer and then used the computer to "blow" it up to the size i wanted to use and to angle the numbers to match the angle of the checkers at the wing-tip's......i don't know, maybe too much work, maybe you can find a easier way to do it......i hope this help's/give's you new idea's......kenncarleton, keep us posted, send us some pick's.....let us know if we can be of any further assistance in contributing to your "success".....KOOLKRABBER47......
ID:	1323874   Click image for larger version
ID:	1323875   Click image for larger version
ID:	1323876   Click image for larger version
ID:	1323877   Click image for larger version
ID:	1323878   Click image for larger version
ID:	1323879   Click image for larger version
ID:	1323880   Click image for larger version
