 NOVA maiden and crash >
Old 12-02-2009 | 07:02 AM
  #76
CGRetired's Avatar
Default RE: NOVA maiden and crash
ORIGINAL: billd76
ORIGINAL: hugger-4641
Yeah I think you'll be fine with that set up too. It may not have all the vertical you could want, mine doesn't, but I have other planes for that.
One more ??? where to you have your CG set. manual calls for 4.5 inches from the leading edge. Had to add seven 1/4 ounce blocks to get it balanced!
One thing that MinnFlyer stated way back when. I had to add about 18 ounces of lead to the nose of my Tiger 120. I hated that.. but it was necessary to get the plane to balance correctly. It flew just fine, but I continued to squawk about it.
His advice was to do what's necessary and enjoy the plane. If that means added weight, so be it. You can move things around to take care of some of that, but I don't think 2 pounds of shifted components is really possible, so put what you have to where you have to, secure it, and fly it. As it turns out, the Tiger 120 was still a very nice flying airplane. Nothing fancy, just a fun and relaxing plane to fly.
CGr.
Old 12-02-2009 | 07:06 AM
  #77
CGRetired's Avatar
ORIGINAL: billd76
Ouch. That's a lot of added weight. I hate that.. BUT..
One thing that MinnFlyer told me way back when. I had to add about 18 ounces of lead to the nose of my Tiger 120. I hated that.. but it was necessary to get the plane to balance correctly. It flew just fine, but I continued to squawk about it. Don't get me wrong, I know you are not complaining. I could have used a different, heavier, engine, but I had the OS 1.20 up front and liked that engine. So, I frowned, and added the weight.
CGr.
Old 12-02-2009 | 07:33 AM
  #78
goirish's Avatar
I had to add a lot of weight to my big bingo. About 18oz. I had moved everything I could to the front but still had to add the weight. Even with that it came in at only a couple of oz's over what the plans called for.
Old 12-02-2009 | 07:52 AM
  #79
billd76's Avatar
ORIGINAL: CGRetired
ORIGINAL: billd76
ORIGINAL: CGRetired
Ya see... you CAN teach an old dog new tricks!!!
Ha!! I wondered how long it would take for the Coast Guard to chime in! If I have actually been taught anything remains to be seen!! Been using a computer for 20 years and still haven't learned how to type properly.
Semper Paradus, Bill!!
Hey, with my electronics background, I would think that electric flight would be a piece of cake... NOT!!! Those things become a mystery at times, trying to coordinate motor/esc/battery with weight and so on.. strange stuff. With glow, well, just put an engine on and fly the thing!!! Well, for the most part.
I was totally shattered when I broke my Venus 40, but realized that it was part of learning. And muscle memory is part of that, and was definitely the cause of my crash. Me, my fault, not the plane.
There have been several suggestions, Minnflyer has a good one. I like my approach because it works for me. (stand behind, right aileron stick movement, right aileron goes up, left goes down) but whatever floats yer boat works just fine as long as the end result is a safe plane and one that is truly ready to fly and do what you want it to do.
Oh.. one thing here, that I found out with using computer radio's including the DX7. It's completely possible to have the ailerons work differently than they are supposed to (both up, or one side up the other side not moving, all sorts of strange things). It all comes in the setup. So, pay attention to that, do the proper mix, and even after binding the settings in, check and re-check, and check again before each flight. It comes automatic to me, and should to everyone.
One thing to remember, and you probably already know this, is to bind with the throttle at minimum and all sticks neutral. This sets up ''fail safe'' to where you want it to be. ESPECIALLY important with electrics because loss of signal could cause the electrics to go to full throttle on you on the bench and could cost a finger or two (don't ask how I know this.. no fingers lost, but 5 stiches on my right index finger tells the tale). With glow, this only is a factor if the engine is runing. But, make sure you bind with the pre-sets where you want them.
Ok.. more than you probably wanted to read, or you probably already knew this, but it never hurts to re-state it for those that don't know.
Semper Fi, Semper Paradus!
CGr.
Thanks. Yeah the Tx setup is key! I only own two electrics, only one if flying, the other is still under construction. I have been just adding fictious models for that last couple of evenings, just to get used to scrolling through the menus and trying to remember the button press procedures, just in case something goes crazy while in the air, then perhaps, but not likely, I could get to the menu that needs addressed quickly. I will set the CG at 4.5 inches and see how it flys. I already have everything foward. About all I could do is add a bigger engine, and replace the elevator control rods with carbon fiber rods, Could perhaps cut a slot through the vertical stab and attach some ply to make the elevator one peice instead of two. But Nah, I think at the moment I'll just fly it like I stole it!!!
Old 12-02-2009 | 08:33 AM
  #80
MinnFlyer's Avatar
ORIGINAL: CGRetired
As for me, Semper En Excretus!
Old 12-02-2009 | 09:03 AM
  #81
billd76's Avatar
Well you're either always sweating or running to the head!
Old 12-02-2009 | 09:09 AM
  #82
MinnFlyer's Avatar
Default RE: [Deleted]
No, just always up to my neck in it
