 Spektrum Question >
Spektrum Question
Spektrum Question
Old 12-11-2009 | 01:31 AM
MetallicaJunkie's Avatar
Default Spektrum Question
I had forgotten to connect the satellite receiver.....here's whats strange I noticed the orange light was solid, as if it were bound to my transmitter but servos would not respond till the satellite was connected ... I thought tthe satellite receiver "was back-up" and that the actual unit itself(ar7000) was the main receiver....is this normal....for the reciever not to work unless a satellite receiver is connected?
EDIT* for some strange reason once i had the satellite connected and linked with my transmitter and working....i disconnected the satellite and it still continued to work,,,, i think everything is ok ......
mods feel free to lock or delete this thread
Old 12-11-2009 | 07:22 AM
billd76's Avatar
Default RE: Spektrum Question
ORIGINAL: MetallicaJunkie
I had forgotten to connect the satellite receiver.....here's whats strange I noticed the orange light was solid, as if it were bound to my transmitter but servos would not respond till the satellite was connected ... I thought tthe satellite receiver ''was back-up'' and that the actual unit itself(ar7000) was the main receiver....is this normal....for the reciever not to work unless a satellite receiver is connected?
I'm confused, how did you disconnect the backup (satellite) Rx? All of my 6200's are hard wired together.
Old 12-11-2009 | 09:18 AM
CGRetired's Avatar
Bill: I think the AR7000 has a quick-disconnect connector for the satellite receiver. It looks something like a mineature telephone cable connector, like a real small RJ45.
CGr.
Old 12-11-2009 | 09:20 AM
Sandmann_AU's Avatar
OK, easy question first - on the AR7000's and above the satellites plug into the main Rx. the AR7000 takes one satellite and has a single Rx in the main box, the AR9000 apparently has two Rx's in the main box, a 3rd in the first satellite, and can have a second optional satellite too.
Now the original question. Spektrum transmits the same signals on two different channels at the same time. If you lose one channel it continues to transmit on the other and tries to reconnect the first. My guess is that when you connected up without the satellite the main box connected on one channel (hence the solid orange) and was trying to connect on the second but couldn't because there was no second receiver, and without the two channels it wouldn't let you have control of the aircraft. When you tried it with the satellite connected it found two channels and let you have control, but disconnecting the satellite made the Rx think it had lost one channel, so it would have left you in control of the aircraft over one channel, while trying to reconnect on the second (which of course was now missing its receiver).
Caveat emptor - this is just guesswork on my part. I'm not a Spektrum technician and may possibly only know enough to get myself into trouble. It seems to make sense though.
Old 12-11-2009 | 01:37 PM
ORIGINAL: Sandmann_AU
I think you nailed it
