7.4 V servos - what receiver ??
Hi there,
I got couple of the new 7,4 volts servos from Thunder Tiger and I wonder if any of my receivers will take 7,4 volts without problems.
I use Futaba R 617 FS 2.4 Ghz and Futaba R 6014 HS 2.4 Ghz.
Any advices ?
Thank you !
Any advices ?
Thank you !
http://www.rcuniverse.com/forum/forumid_157/tt.htmea
I have no idea what the answer is. But I do suggest asking your question in the link above. That is the link to the forum that deals with all things radio related. I believe there are reps from the differant manufacturers in there. Good Luck!
the Futaba 14 channels will work with 7.4V without any problems. Giant Scale airplanes use lipos without regulator in 7.4V for the hitec 7950 servos and directly pluggled to RX withou any single issue...so you will be fine.
