Balancing a Bi-Plane
My Feedback: (8)
Well, it depends, my hostetler skybolt has the CG on the leading edge of the lower wing, it would almost be off the trailing edge of the upper wing, usually most bipes are balance upright, but this skybolt I have plans for and the kit needs to be balanced upside down. Where is the mark on the plans or in the instructions?
PA
The easiest (and safest way) is to use a sling. See my messages at http://www.rcuniverse.com/forum/m_17...tm.htm#1715012
I have had three biplanes and I have no idea how I balance them (that is, I have no plan on how to do it). One is my own design so I had to decide on the CG location. I just balance it. Top wing, bottom wing, fuselage. If the CG is in mid-space, it will give you an opportunity to solve the problem and you will learn a lot from that. That point is always only a starting point. Slight CG adjustment is usually needed for optimum performance.
When I flew rubber powered freeflight, a good starting point for bipes was 1/3 the average cord of both wings. Witch is not as simple as it sounds. I have a diagram in a book called 'Rubber Powered Flying Models'-By Don Ross but I can't reproduce it.(copyright)-sorry -BW
