 Fuel resistant spray paint >
Old 01-29-2010 | 11:40 AM
Default Fuel resistant spray paint
Are any of the hardware store spray paints like Rust-Oleum or Krylon fuel resistant? Rust-Oleum makes an Epoxy appliance paint would it be fuel resistant?
Gary
Old 01-29-2010 | 12:28 PM
opjose's Avatar
Default RE: Fuel resistant spray paint
Krylon with a primer base works VERY well.
I use it to fix cracked fiberglass cowls all the time and it's never been dissolved by glow fuel.
Old 01-29-2010 | 02:15 PM
Campy's Avatar
MOST colors (but not all) in Rustoleum are fuel resistant, HOWEVER, Rustoleum needs to cure for a MINIMUM of 2 weeks (preferably 3 - 4 weeks) to become fuel resistant. If you are not sure (or want a little "edge",) give it a clear coat with a Water Base Polyurethane. WBP is fuel resistant after about 7 days cure time - Please note that I said FUEL RESISTANT, NOT FUEL PROOF.
Old 01-29-2010 | 07:55 PM
Thanks for the info. I am going to paint the servo compartment white after I finish the rebuild.
Gary
Old 01-29-2010 | 11:08 PM
jeffie8696's Avatar
Ihave had great luck with Rustoleum, Iallow it to dry for quite a while though.
Also have good luck with Testors enamels on engine parts, all you have to do is bake them in the oven for a while to cure the paint and it seems fuel proof so far as my testing has discovered.
Old 01-30-2010 | 12:30 PM
opjose,
Would you elaborate please.
What type of primer base are you using?
KW_Counter
