 Wing for Tower 40 RTF >
Old 03-01-2010 | 09:12 PM
Default Wing for Tower 40 RTF
I need a new wing for my Tower 40 RTF, but the wing costs $75. Has anybody tried using the Tower 40 ARF wing as a replacement for the Tower 40 RTF wing? Buying the ARF wing would save me quite a bit of money. The only difference that I can see is that the RTF wing comes with a metal dowel rod and screws to hold the wing halves together.
The ARF wing would require more work to assemble, and it makes more sense to buy the ARF wing if it will work on the RTF plane.
Thanks!
Old 03-01-2010 | 09:20 PM
mclina's Avatar
Default RE: Wing for Tower 40 RTF
I can't imagine that it wouldn't fit. Trainers have flat bottomed wings, I would expect you could interchange almost any trainer wing with another of similar size.
Old 03-01-2010 | 09:21 PM
G.Barber's Avatar
If the wingspan and chord are the same, I see no reason why the ARF wing would not work.
Old 03-01-2010 | 09:24 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Even with the differences you mentioned the wings are the same. You can do a direct swap out.
Ken</p>
Old 03-01-2010 | 09:28 PM
mclina's Avatar
I can't believe anybody would pay $75 for the RTF wing. You can buy the entire ARF airframe for that much. The ARF wing will definitely fit.
Good luck
Old 03-01-2010 | 09:54 PM
Of course Tower Hobbies doesn't recommend it because they want people to purchase the RTF wing for more money. I plan on buying the ARF since $75 for the RTF is ridiculous.
Old 03-02-2010 | 06:19 AM
mclina's Avatar
I assume that since the RTF comes with the aluminum joiner tube, that the instructions do not include epoxying the wing halves together. My Alpha 40 wing was like this, they just told you to slide it on the tube and wrap it with tape. I epoxied mine anyway.
Without the tube, the ARF wing is probably a bit lighter. Not that it really matters much.
Old 03-02-2010 | 07:51 PM
My Feedback: (8)
Actually looks like a piece of music wire. The ARF wing has a plywood diahedral brace and epoxy. Everything else is pretty much the same.
Jim
