Reusing gear from less flown planes
ORIGINAL: bigtim
thats part of the reason i have been installing Voltwatch devices in my planes to watch the charge levels on the batterys, if I charge one up and a few days later the voltage has dropped I know there is something wrong, and I check the battery.
My Feedback: (13)
ORIGINAL: SushiSeeker
I have a maintenance cycle for my batteries. About once a quarter, I cycle each battery and make sure I top it off with a trickle charge. I do this with other batteries around the house, too.
ORIGINAL: bigtim
funny thing I just came across a couple of less used batterys in a box I cycled them a couple of times and they seem to be doing well, after a few days there still holding a full charge saved me a few bucks, since I have a couple of planes that they will work well in.
With imited space in my house and garage [now cabinet shop], I keep almost all of my planes and gear in a 5' x 9' cargo trailer so have set myself a limit of 4 planes at any given time. Not to say that won't go up if I have room but for now keeping 4 flying is all I can do. With my budget, reusing gear is not an option, it must be done. Most of my gear and planes are used but I make sure they are in tip top shape. Transmitter is very old 72MH Futaba which I sent in for refurb shortly after buying which camne with four receivers.
Gary
Gary
For electrical models, I have seen some pilots using a power-control module that they move form model to model of similar dimensions.
That module contains a motor, esc, Rx and battery, and slides into the nose of each model.
Then, the servos of each model are connected to the Rx.
ORIGINAL: opjose
Flight ready
1 composite gasser
4 balsa gassers
8 glow planes ranging from a .40 through 1.80's
4 .40-.50 sized electrics
4 fiberglass / balsa smaller electrics ( e.g. Reactor EP, Lancair EP ).
2 large fiberglass / balsa EDF's
5 foamy EDF's
About a dozen awaiting construction...
I have not purchased a new plane this year, so my ''addiction'' is certainly under control... really it is!
Flight ready
1 composite gasser
4 balsa gassers
5 foamy EDF's
