 Are these mufflers the same? >
Old 03-31-2010 | 04:22 PM
tripower222's Avatar
Default Are these mufflers the same?
Are these mufflers the same? The Towermuffler is out of stock butI think the Aquacraft muffleris the same. I think both brands are hobbico companies does anyone know if there is a difference.
http://www3.towerhobbies.com/cgi-bin...XJB16&P=SM
http://www3.towerhobbies.com/cgi-bin...LXMMV7&P=0
Old 03-31-2010 | 04:30 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Default RE: Are these mufflers the same?
They look the same to me. If you read the descriptions they say that they both fit the same engines, so you should be safe getting it.
Ken
Old 03-31-2010 | 06:19 PM
jeffie8696's Avatar
I see it at Tower all the time. Often they will even have two different prices. This is probably the most common muffler size Ican think of, fits a LOT of engines.
Old 03-31-2010 | 10:58 PM
bonebreak's Avatar
One states that it doesn't fit the Thunder Tiger .42, but the other one does. Not sure what the difference between them are, but it sounds like there is a difference.
Old 04-01-2010 | 07:10 PM
I called Hobbico tech support  they gave me a funny answer the guy said " I cant tell you there the same but there isn't really a difference."
Old 04-02-2010 | 08:41 AM
Bax
They're essentially the same.
Old 04-02-2010 | 06:58 PM
Thanks Bax,Im convinced its the same muffler in a different package. I installed it(the aquacraft)on a 46FXiand with a 11x5 it went from 13200 to 14100 RPM and my Ultra Stik went to unlimited vertical climb, not bad. I havereada lot of commentshere on RCUon the praising the Tower muffler and I can see why.</p>
