 RX Battery Pack for Spektrum ar6200 >
Old 05-29-2010 | 09:20 AM
DenverJayhawk's Avatar
Default RX Battery Pack for Spektrum ar6200
I need a 6V pack for an AR6200. I've checked servo city and batteriesamerica. A 6V 2000mah pack is about $26. Any other recommendations where I should check?
Old 05-29-2010 | 09:22 AM
MetallicaJunkie's Avatar
Default RE: RX Battery Pack for Spektrum ar6200
ORIGINAL: DenverJayhawk
http://www.3epower.com/servlet/the-9...RC-NiMH/Detail those are the one i use in 1.20 on down planes.... 14.99 shipped
Old 05-29-2010 | 03:10 PM
I just got 2 from this Ebay seller that came labeled as from 3epower. $25.95 Shipped for 2 6V 5 Cell flat packs with universal connectors, $2.00 added shipping per additional items.
http://stores.ebay.com/BATTERY-ISLAND
Old 05-30-2010 | 06:52 AM
CGRetired's Avatar
RadicalRC www.radicalrc.com is a great source.
CGr.
Old 05-30-2010 | 10:02 AM
The Ni-Cd charger that came with my old Hitec radio system says:
RX 4.8V DC 55mA
Would this work with a high capacity 6V RX pack?
Old 05-30-2010 | 07:32 PM
CGRetired's Avatar
Well, probably not. Note the voltage difference. It may charge up to a voltage higher than 4.8 but more than likely not 6 volts. I've not done it myself, I have several chargers that will charge a 6 volt pack so I don't often use my wall charger even for 4.8 volts.
CGr.
Old 05-31-2010 | 02:49 AM
I would not trust a charger that is not rated for 6 volts. When making the jump to 6V batteries it is time to invest in a good charger that can charge as well as discharge.
Old 05-31-2010 | 10:23 AM
if you dont wanna get fancy or expensive...this is a good charger http://www.maxxprod.com/mpi/mpi-9.html scroll down to CH96N
Old 05-31-2010 | 04:06 PM
Thanks for the info, Metallica. I'll check that out.
