 Wing Bolts >
Wing Bolts
Wing Bolts
Old 06-16-2010 | 02:58 PM
Default Wing Bolts
hi guys - building a cg super chipmunk - just wondering what are the best type of wing bolts - i'm thinking of using nylon with blind nuts but not sure of the size - probably 4 or 5m - any thoughts appreciated thanks
Old 06-16-2010 | 03:11 PM
Default RE: Wing Bolts
Hi!
What size is the plane???
I use one 4mm nylon bolt on my Q-500 racers and two 4mm nylon bolts on my DC-3
ID:	1453949   Click image for larger version
Old 06-16-2010 | 03:38 PM
I use them too, but replace them every Spring.
Just in case,
Bob
Old 06-16-2010 | 03:42 PM
Lnewqban's Avatar
scott,
If you are building the 60 size kit, you can find data and manual here:
http://www.carlgoldbergproducts.com/...ma0952.html#13
http://manuals.hobbico.com/gpm/gpma0952-manual.pdf
Check page 23, where two 4 mm bolts are specified.
Old 06-16-2010 | 03:44 PM
hi jaka - it's 64" wingspan - the kit has two imperial steel cap head bolts that i'm thinking of changing for nylon
Old 06-16-2010 | 05:55 PM
DavidAgar's Avatar
My Feedback: (108)
In the US, we would use 2 1/4 X 20 nylon bolts if it is a 60 size plane. Good Luck, Dave
Old 06-16-2010 | 06:07 PM
thanks dave - do those dimensions equate to 4mm x 40mm - i'll use either 4mm or 5mm nylon screws - i'm guessing the 1mm won't make a difference either way
Old 06-16-2010 | 07:51 PM
A #8 imperial is about a 4mm bolt
A #10 imperial is about a 5mm bolt
Stan
Old 06-16-2010 | 09:15 PM
Dave: You really have me aghast with the wing bolt size you mention, 2-4/40's??? I and all others I know use 2-1/4/20's. Perhaps you made a typeing error?
Old 06-16-2010 | 09:55 PM
Lnewqban's Avatar
I believe that the most used sizes in USA for nylon wing bolts are #10-24, #10-32 and 1/4"-20, in lenghts between 1" and 3".
http://www.boltdepot.com/fastener-in...crew-Sizes.pdf
Old 06-16-2010 | 10:13 PM
DavidAgar's Avatar
My Feedback: (108)
TedMo, you are correct. The mind said one thing the fingers typed something else. I do know that the Goldberg Cub and Chipmunk , both 60 size planes use 2 each 6/32 bolts with fender washer's for wing bolts. Thanks once again, Dave
Old 06-16-2010 | 11:13 PM
ORIGINAL: scottm50
Hi scottm50,
My CG Super Chippy is >ten years old and the original allan head bolts are still working fine. Given the way the blind nuts mount to the fuselage I think the modifications to fit nylon bolts wouldn't be worth the effort. Don't forget to reinforce the UC mounting blocks.
Cheers,
Colin
