Fire!
Old 07-23-2003 | 03:03 AM
Default Fire!
Okay, I'm not sure what happened here, but I connected my servos and battery to my receiver for server centering and all of a sudden wires from the battery to the receiver started pouring smoke out. I had the battery hooked up earlier, without the Switch & Charge jack and everything was fine. Could the jack have shorted out? I guess I have to buy a new battery too, as the wires are absolutely cooked.
Burned fingers.
Old 07-23-2003 | 03:09 AM
Default Fire!
Forget it. I found out what it was. The wires on the battery shorted on each other. The casing must have had a hole in it or something. Never seen that before.
Old 07-23-2003 | 04:00 AM
Default Fire!
I hope the receieve was not damaged...
Old 07-23-2003 | 12:33 PM
Default Fire!
Yeah, me too. I won't know until I pick up another battery today. The wires were sparking and smoking all the way from the battery, through the switch (which may have started it) to the receiver.
Old 07-23-2003 | 12:38 PM
Thunderhead's Avatar
Default Fire!
Been there
Old 07-23-2003 | 01:08 PM
Default Fire!
Thunderhead, in reply to your e-signature, if she'd been in the air, it would have been pretty spectacular. I can just imagine what a smoking battery would have done underneath a plastic tank full of nitrous. If she ever goes down flaming, I just hope the camera is handy. (Keep in mind, this is my first plane ever, and it's not an ARF, so I just want to fly it - even once!)
Old 07-23-2003 | 02:26 PM
MinnFlyer's Avatar
Default Fire!
I can answer that WK
Back in the 70's my dad was flying a pattern plane, and I was his caller. As he crossed the threshold for a low runway pass, the plane suddenly wobbled, did a half roll to inverted, then smashed spectacularly into the runway.
Cause: The battery pack had been in a previous crash and the two leads had not-previously-noticed bare spots in the wires.
Pack shorted out, plane came down -BOOM!
Old 07-23-2003 | 09:49 PM
FLYBOY's Avatar
Default Fire!
I had that happen in my huge G-202 twice. The first one I caused by putting a wing screw through an ail ext with the radio on, everything melted because it took a while to get the wing off. Not good. I sent the rec in and they checked it, cheap ins. Cost me $15 to make sure it was ok. Replaced all the servos, bat, switch and put it all back together, pluged in the bat and the bat and switch melted. That was a bad switch. Ticked me off. Ruined another battery and switch. It was a cheap switch. I threw all the others in the drawer away because they were all new and came from the same dealer and I didn't trust them. Ordered a bunch of futaba switches. Those I know are good. New battery too.
Hate to see it. Send in the RX to make sure it is ok.
