6v receiver pack voltage
When a 6v battery is fully charged what would the voltage normally read at?
What would the voltage read at to the point to where the battery will no longer operate the servos?
I'd like to know,
hulio
I'd like to know,
hulio
Balsabringer (09-29-2024)
I found this using a quick search using Google.
I did the research, you do the math.
CGr
A fully charged NiMh cell measures 1.4–1.45 V (unloaded), and supplies a nominal average 1.25 V/cell during discharge, down to about 1.0–1.1 V/cell (further discharge may cause permanent damage, and the risk is increased with multi-cell packs). This is typical and may vary with application and current draw levels.
CGr
My Feedback: (108)
The top end voltage on a fully charged pack would be about 7.2 volts, without a load on it. As for how low it will go and still operate servos, that would depend on what kind of servos that you are using and how many. If you are using a 2.4, they have a point on the low end of the battery voltage that will cause them to rebind. The servos might still work, but the receiver does not. Good Luck, Dave
7.2 would be the nominal voltage for a 5 cell pack. A NiCad is considered discharged at 1.1v, but will still operate the servos and RX for a while.
ORIGINAL: Dr1Driver
Mine typically read 1.4 to 1.45 V. per cell, right off the charger...just a wee bit warm...then after sitting for a few hours are around 1.35 (pack returned to ambient temp )
Just before the pack peaks though, the V. can read 7.5 maybe 7.6 but that drops immediately after the charger is shut off.
ORIGINAL: hulio516
I'd like to know,
hulio
I'd like to know,
hulio
Something to be aware of.
