Which glow plug for an Thunder Tiger .46 Pro?
You need more info. Glow plug selection depends on many factors to give you the best performance. If you are running high nitro you may want a colder plug , less nitro = hotter plug. Merlin plugs has a wide selection. here is a good link http://www.blueangels.rchomepage.com/glow_plug_info.htm
please excuse me for going of of the question? but i have a question about a o.s. 40 la.max i have been using the o.s. #8 plug i have merlin plugs lying around can i use this in my o.s.the plug is merlin/2003 hot plug[:-]
The O.S. No. 8 plug will work well with 10% nitro fuel on the TT Pro .46 engine. A hot Merlin plug should work fine for the .40 LA as well.
I usually go with the Fox RC Long glow plug as a good default plug for most 2-stroke engines.
