using a 9g servo for throttle
I am putting together a Lanier Sea Bird and what to know if I can use a 9g servo for the throttle. I want to mount the servo in the engine pod and I don' have room for the mini or standard servo. Powered by a 91 4 stroke
I went to do something similiar on a larger engine. After I posted a photo of my setup, I was immediately told to use a bigger servo.
I was very glad I listened to the advice.
A glow engine can produce strong short pulse vibrations, that will strip the gears off a 9g servo.
Don't do it.
Don't do it.
OK enough said. I will have to work out something different. I don't like the way they show in the plans. Maybe I can snake a cable up inside the pod. My SeaMaster 120 had all kinds of room so I could put the servo in the pod.
I would 2nd the idea of a beefier servo, and the flex cable...
The vibration really beats up the throttle servo in that sort of installation.
However...one other consideration might be something like a vibration insulator, similar to a profile 3D type throttle servo installation?
I lost a Hitec HS-81 in my Tribute...then used an HS-85 and a "servo saver" to help cushion the pushrod to output arm linkage. That servo still lives after a couple hundred or so flights.
http://www3.towerhobbies.com/cgi-bin...?&I=LXD646&P=7
Do you have room in the pod for an HS-85 size servo?
i have used the hxt 900 (9g servo) for a number of engines, mainly .46's but ive used it on a magnum .91 fs and it worked just fine.
some of these servos are over a year old and still working great as throttle servos.
one thing i do use is thin wire for most of the servos so its much harder to transmit vibration through and damage the servo
ORIGINAL: proptop
My Feedback: (85)
I used a Hitec HS-81 on my Sea Bird with a K&B 65 Sportster. The servo was short lived about 20-25 flights around there, I think the vibration got to it. As it would start wandering all by itself like a bad pot.
According to Hitec the HS-82MG has the the better electronics like the HS-85 and should work better.
Adding a weight to the pushrod to lower the frequency that the rod will respond to will protect a servo.
An old post that shows this concept.
http://www.rcuniverse.com/forum/m_83...tm.htm#8393174
I have used a 9g servo a few times with any problems. Just make sure the carb barrel is easy to turn. I had to free off one with a little fine wet and dry.
I can't see that using a 9gr servo would be a problem. I'd opt for metal gear. There are quite a few aircraft that use these servo's successfully. The trick is isolating the sources of vibration.
I have a mini std GWS bb that I cut the mounting hole brackets off and I am going to mount it on the side. I will attach it with E-6000. I think that will take care of any vibration and it will have enough torque 47 oz/in.
I have an HS-81 that has been used as a throttle servo for a DL-50. I have well over 1,000 flights on the plane and I have only gone through one. I haven't had any problems with HS-81's as throttle servo's since then. Hope this helps.
ORIGINAL: NateFlite
