Second Plane
OK I fly on channel 24 for with my trainer and would like to stay on this channel. could anyone show me by link a Receiver I can use and the crystal I would need?
I have a futabu 6 channel radio.
I have had very good experiences dealing with FMA direct. I think its fmadirect.com. I have about 8 of their flight packs. Good stuff at reasonable prices. God flying, Dave
Here's a link to Futaba receivers and crystals.
http://www.servocity.com/ServoCity/P...receivers.html
Just go anywhere, towerhobbies.com, or FMA or Hobby Lobby, and ask for a futaba (or Futaba compatible) with a channel 24 crystal.
Futaba requires that the receiver be either 'high or low band' (24 is low) but the dealer or hobby shop will provide the right one.
I have used Futaba, Hitec and FMA, and all have worked well.
Dennis-
Dennis-
OK So I am getting this http://www2.towerhobbies.com/cgi-bin...?&I=LXXJ55&P=V
can someone supply a link directly to the crystal I need? Thanks for being helpful.
At the bottom of the page it says accessories needed in small print. That's your link. Could have been a little easier to find
http://www2.towerhobbies.com/cgi-bin...T=1&I=FUTL0311
When you follow the link under required items, it takes you to the page with the crystals. When you click the "Buy Now" button under the price, it takes you to a frequency selector page. That's where you specify what frequency you want. You'll want to select channel 24:72.270 MHz from the drop down list. It should then add the correct crystal to your chopping cart.
This is what you want to see in your cart: FRC824 RX XTL FM D LO 24 72270
