Futaba
G`Day
Can someone please advise me on Servos, am using the Spectrum DX7 Radio and building a new plane which still has to have servos and receiver installed. Can I use <u>Futaba</u> <u>digital servos</u> with the Spectrum DX7 2.4 ghtz and the Spectrum 7 channel 2.4 receiver?
Or am I asking for trouble if Iuse servos from Futaba because I am using Spectrum radio and receiver.!!
Any feedback would be greatly appreciated!!!!!!!
dutchy50
dutchy50
PA
I have had no issues using futaba servos snd DX7 and Spektrum rx's. A couple of my planes have JR and futaba servos mixed together. The ones that do have digitsl servos are hi-tech digi servos
My Feedback: (-1)
The RXs don't have any idea of the make or model of the servos being used. Futaba used to have a tab on there end that required being removed before it could be used in other brands of RXs. Been a long time sense I bought a Futaba servo so I'm not sure if they still play that game.
WI
ORIGINAL: daveopam
I have several planes with two different brands of servos in them. I think Airtronics are the only ones that don't just plug and play.
David
David
Not true, they will if you have the airtronics with the blue(z connector) plugs.
dutchy50:
You did say "Digital" servos in your original post. I agree with all of the above, but I must add that you may... may... be using servos that are way advanced for your application.... and more costly than you may need to get the job done.
Many, if not most, of us, use basic servos, we normally suggest Ball Bearing servos vs. the bushing type. But, a basic servo, at about $10 US will do the job on most of the aircraft flown by most of the beginners in this forum.
You decide on what you want and how much you want to pay... but I have a whole pile of servos, both basic and advanced, and for the type of flying I do, and considering that this IS a a beginners forum, I would suggest that you stick to basics and use the good quality Futaba, Airtronics, Hitec, or other quality basic servos on your basic flyer.
I use basic ball bearing servos on most of my planes and have not yet had a problem with any of them.
CGr.
CGr.
My Feedback: (-1)
ORIGINAL: CGRetired
dutchy50:
You did say ''Digital'' servos in your original post. I agree with all of the above, but I must add that you may... may... be using servos that are way advanced for your application.... and more costly than you may need to get the job done.
CGr.
dutchy50:
CGr.
Gene
RCU Forum Manager/Admin
My Feedback: (9)
ORIGINAL: airtime82
ORIGINAL: daveopam
David
David
Ken
CGRetired
I know this is a beginners forum! but still would like some feedback!
Maybe you could tell me which forum I should use?
Am actually building a 1/7th P51 Top Flite kit which is where I want to use the digital servos
Am still having lessons and also have Trainer which I will be using for quite a while until I get more confident in flying.
The P-51 is a building project for winter while I fly the trainer!!!
dutchy50
dutchy50
Hold on a second, Dutchy.. my comment wasn't a scold, it was just a comment and not intended to be negative. So, relax and enjoy the view. If you want a recomendation, well, about 90% of my servos are Airtronics, and a good number of those are 94102Z basic servo. And the cost here in the US is about $10.00. And they work just fine.
Yeah, Gene.. I forgot.. my Spektrum DX7 came with "digital" servos. I was thinking of those rather costly digitals that are more suited to a gas powered 30%'er. Sorry for the confusion.
CGr.
CGr.
