 Webra .61...Fuel recomendations? Do i need a head shim?? >
Old 09-11-2010 | 09:15 AM
Default Webra .61...Fuel recomendations? Do i need a head shim??
An airplane collector/builder/flyer who has been out of flying more than 15 years brought me several planes and a box of engines asking for help to get back flying. ( SIG Kadet Seniors and a Telemaster 8ft wing) I read somewhere in the past about needing a shim if you are running higher nitro fuel. Is this correct? What fuel are you running in your Webra 61?
Two of these are the blackheads and one is a silver head. None have mufflers. These motors are in great shape! The only muffler I'm able to fing is the HB 300901.
I am just starting back into r/c myself...any help/suggestions will be greatly appreciated.
Sleepin
Old 09-11-2010 | 12:52 PM
Default RE: Webra .61...Fuel recomendations? Do i need a head shim??
we ran the Webras on K&B 500 and they were the loudest meanest 60's in their time............i'd look for a fuel that contains more castor than synthetic and still add 3-4 ounces of castor to the fuel.
Powermaster 10% would be great for the Webra with some Castor added. you won't need any head shims.
it's a good choice for those planes with a 12x6.
as a rule though, no nitro is needed.
read this from the Webra site, and make your choice of 0-15% nitro as needed.
http://www.webra-austria.at/download/en/motor.pdf
Old 09-11-2010 | 01:00 PM
Most Webras sold in the states don't like more than 10 percent nitro. You can buy some FAI (zero nitro) fuel and dilute the mix down it you cant find 5 or 10%. Even try the FAI by itself There will be little or no power advantage to running higher nitro and a head shim in the Webra, just costs more to run. Fuel, glow plugs and engine load are your controllable tools.
If that engine has an old plug in it, start out with a fresh one like an OS #8, Enya #4 or #3.
Old 09-11-2010 | 01:12 PM
ORIGINAL: freakingfast
that's wierd, back when we first started using the Webras, guys like Kirkland, Jim Martin, Ron Chidgey and even Phil Kraft found that it didn't perform on FAI fuel like it did with 5-10% nitro.
guess we had run these all wrong. but i guess you were there in the late 60's so like the old saying goes,
learn something almost new everday
Old 09-11-2010 | 01:46 PM
ORIGINAL: summerwind
The engine will run fine without nitro. That DOES NOT mean you won't get a tad more out of it with some nitro. If you run too much, and it starts detonating, you can turn that nice vintage iron into scrap in a matter of seconds though.
If any engine produces adequate power to fly the intended airplane with no/low nitro, using more is simply a waste of money and glow plugs.
Old 09-11-2010 | 02:19 PM
in case you miss this
Old 09-11-2010 | 03:56 PM
That's why I said "try" some FAI. Some Webra engines really have a tough time with 15% like the speed 55 gt black head (discontinued) ringed speed 35 (discontinued) or the newer little power house speed 36. These engines when run on 15% either beat clearance in the rod end which lowers the compression (some think it's a long break-in) or it out right snaps the crank at the pin or port. Even on tuned pipes the 55 and 36 engines run great on 10% and break in quickly (the ringed 35 takes a while). The 55 runs fine on 0% IF the rod end is not already hammered.
I's better to start low nitro and work up. When the engine has less power, surging or blowing plugs on more nitro after opening up the high speed needle and even trying a colder plug, that's a pretty good sign you've gone over the nitro limit. When it's cold out you may get away with the higher nitro, so if it's running bad when it gets hot you know what you need to do.
