stupid electric motor question
I'm researching my second plane (flying a hobbyzone super cub now) and I have a stupid question about electric engines.
I'm looking at two planes, one has a "15 size brushless outrunner motor" and the second has a "480 size 960kv brushless outrunner motor". Which is more powerful? Does anyone have a chart they can post or a link to a list of engine sizes and their power output or list them in order of least powerful to most powerful? |
RE: stupid electric motor question
15 is bigger, the smaller motors run up to around 400, 450, 480, after that, the bigger ones start at .10 size then go up.
10 15 25 32 and so on. The 2 digit numbers signify the approximate power of a 2 stroke nitro engine. |
ORIGINAL: scooterinvegas 15 is bigger, the smaller motors run up to around 400, 450, 480, after that, the bigger ones start at .10 size then go up. 10 15 25 32 and so on. The 2 digit numbers signify the approximate power of a 2 stroke nitro engine. So based on what you've told me, it looks like the 480 is probably the better second plane! And here I thought it would be more powerful and NOT be a good second plane! For the record, I'm comparing the E-flite apprentice 15e and the parkzone T28D Trojan. |
The apprentice is 14" wider and 10-15 oz heavier. Even with the bigger motor it might not be faster or "more powerful". I would buy the T-28. They fly great stock, and most hobby shops can get parts faster. Two of the LHS I go to stock most the parts on the wall.
Plus, when you get tired of the stock T-28, just add a E-flite power 15 or 25 and a APC 11X7-E and it will fly like a newer/faster plane. |
ORIGINAL: scooterinvegas The apprentice is 14" wider and 10-15 oz heavier. Even with the bigger motor it might not be faster or "more powerful". I would buy the T-28. They fly great stock, and most hobby shops can get parts faster. Two of the LHS I go to stock most the parts on the wall. Plus, when you get tired of the stock T-28, just add a E-flite power 15 or 25 and a APC 11X7-E and it will fly like a newer/faster plane. |
| All times are GMT -8. The time now is 01:10 AM. |
