RE: ballancing
John
Ya need a couple more props on the wall.:D |
RE: ballancing
What happens when you go inverted? :D
Just kidding there, John. Good approach, for sure. Irish.. hmm.. a pretty good idea. Now, if I could squeeze that in between the engine compartment cheeks.. :D CGr. |
RE: ballancing
Well, Irish.. you certainly know where to go to get that odd-ball prop you have always wanted/needed... :D
RE: ballancing
1 Attachment(s)
A little wrap of tape or drip of glue works miracles;) Ahh Props eh, oh there are more:
Here is a variation on putting the battery where it needs to be. On this airplane the battery pack is back at the stabilizer when the engines or on. When you fly it without the engines the battery pack quickly plugs into a nose compartment with a permanently set up Y for the power leads front or rear. John ;) |
RE: ballancing
Heading out for the dealer show in Vegas this morning I'll be on the lookout for more props, Jets cause cancer of the wallet:D
John |
RE: ballancing
ORIGINAL: goirish I've never had a backfire in the air. Normally just when I am starting a 4 stroke. |
| All times are GMT -8. The time now is 12:18 AM. |
