RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   problems with a ASP 75 Carb (https://www.rcuniverse.com/forum/beginners-85/10605826-problems-asp-75-carb.html)
goirish 07-04-2011 01:25 PM
I have a 75 ASP that is leaking where the fuel inlet attaches to the carb. If I close the carb off and pump fuel in the inlet it sprays out behind the needle valve. I can post a picture if that will help. I have tighten it down about as much as I can without stripping the threads. There are 2 washers, one on each side of the inlet and that is where it is leaking. Any suggestions, other than file 13.[&o][&o][&o]
delman 07-04-2011 04:42 PM
RE: problems with a ASP 75 Carb
"Just Engines" in England probably stocks the gaskets (washers). You could also check with Hobby People about Magnum carb parts that would be the same.
http://www.justengines.unseen.org
jester_s1 07-04-2011 08:30 PM
Are you sure something isn't cracked? It should seal pretty well without the washer even on there. A drop of blue Loctite should seal it up if there's not any damage.
goirish 07-05-2011 02:19 AM
I put some red gasket sealer on the washers and it seemed to correct the problem. I still think I will order a couple of washers.
