DX6i
I have the DX6i transmitter and its program to the You Can Do aircraft. I have the ailerons mix but they are moving in the wrong directions. When I go into the setup to reverse them they only do one side of the ailerons and not both. How do I get both to reverse correctly?
RE: DX6i
ORIGINAL: mrcoolpop I have the DX6i transmitter and its program to the You Can Do aircraft. I have the ailerons mix but they are moving in the wrong directions. When I go into the setup to reverse them they only do one side of the ailerons and not both. How do I get both to reverse correctly? If i remember correctly you need to revierse your aux channel. that will make them move the correct way. |
RE: DX6i
I'm not a Spektrum guy but if you have dual channels you have to reverse both channels
RE: DX6i
Do you still have a copy of the manual? if not i can find it.
RE: DX6i
You probably have one channel mixed to another instead of using the ( much easier if available ) flaperon mix.
In this case you may need to swap the mix values... e.g. if they are at -100% to 100% now for the second channel reverse them so they read 100% to -100%. |
RE: DX6i
Thanks opjose, I change the values to +100 instead of -100 and the worked. Again, thanks to all in helping me resolved this problem. |
| All times are GMT -8. The time now is 05:51 AM. |
