RCU Forums
-   Beginners (https://www.rcuniverse.com/forum/beginners-85/)
-   -   Geared to Direct Drive (https://www.rcuniverse.com/forum/beginners-85/10730734-geared-direct-drive.html)
JH313 09-23-2011 11:28 AM
I have a quick question:
Can I take the geared drive off of my 400 sized electric motor. It is going to be reused from a soarstar to a smaller plane (called for a 380, but i didn't have one).
Also, would a 5x2.5 prop be too small. Is there any negative to a small prop on an electric (other than less performance)?
Thanks.
CGRetired 09-23-2011 03:47 PM
RE: Geared to Direct Drive
The motor will try to turn at it's KV rating. If the prop is "smaller", more than likely it will approach that RPM point better than a larger one. It won't exceed that RPM if that's what concerns you.
If the motor bolts on and the gears match, I can't see any downside to it.
CGr.
jimmyjames213 09-23-2011 03:56 PM
ORIGINAL: JH313
Thanks.
if your plane calls for a 380 the 400 would work just fine, it is not much bigger.
compared to useing the 400 motor with no gear box, the 400 with a gear box will be much better
CGRetired 09-23-2011 05:35 PM
From what I read, after looking for information on this comparison, they basically are the same motor and, basically have the same specifications. As I said, if the "bolt pattern" and gears match up with the gearbox, then go ahead and use it.
CGr.
