Satio Question
I just built the You Can Do ARF plane and I put the Satio 100 engine on it. It appears that the fuel tank is too high and the carb is too low. This causes the fuel to constant flow causing it to flood. Other than turning the engine to lift the carb higher is there any other fixes that I can do?
Thanks, |
RE: Satio Question
Cline Regulator will fix it, but it's $60.
David |
RE: Satio Question
It's one of the problems about ARFs. When you ASSEMBEL it your stuck with where they had room or just figured this is a good place for the fuel tank. Not sure how you have the engine mounted but it's one of those things you have to think about when ASSEMBLING. I have been able to get inside the tank area on some ARFs and remove the wood area the tank mounts onto and remove it to lower the tank. Other then that flipping the engine may be your only way.
RE: Satio Question
Where can I get this Cline regulator from? Looked online but nothing is coming up.
RE: Satio Question
http://saito-engines.info/pumps.html
http://www3.towerhobbies.com/cgi-bin...&I=LXDG59&P=ML A Saito engines website with some good information Tower's website with a regulator available for sale. |
RE: Satio Question
GB is on the money.I usually put a rape and pillage carbon steel bit into the dremel and hack out the braces in the middle so you can get your fingers in there and hold the engine mount nuts while you try to line them up and get them threaded.Plus it gives you room to fit whatever tank you like there,no fiddling with fuel lines either.After that i run a light bit glass round the forward bulkheads where i removed the cross bracing on the front formers,sweet as:)
RE: Satio Question
ORIGINAL: Old Fart GB is on the money.I usually put a rape and pillage carbon steel bit into the dremel and hack out the braces in the middle so you can get your fingers in there and hold the engine mount nuts while you try to line them up and get them threaded.Plus it gives you room to fit whatever tank you like there,no fiddling with fuel lines either.After that i run a light bit glass round the forward bulkheads where i removed the cross bracing on the front formers,sweet as:) For those of us that still build our planes tank location is one of those considerations we think about before the glue bottle is even opened up. For those that ASSEMBLE an ARF the Rape and Pillage is often the best way to do something. Another way of doing it is getting a pumped engine. They don't care where you place the tank. The Saitos are great engines but they still don't have a pumper in the line up that I have seen. |
RE: Satio Question
RE: Satio Question
Fuel pinch clips are only four bucks: http://www3.towerhobbies.com/cgi-bin...LXNSD1&P=7<div>
</div><div>K & S clips are good too. </div><div> </div><div>I agree that getting the carb and tank centerlines sorted should be done first tho. <div> </div><div> </div></div> |
RE: Satio Question
Not familiar with the clips so couple of question. How exactly are the use and can they be use with the cowl on the airplane? |
RE: Satio Question
The fuel line to the carb needs to be exposed for the clips to be easily used. The K & S I use on my helis are a simple, narrow 'V' shape that get pushed on/off, they stay trapped when not in use. No moving parts. That tank must be pretty high if you're having siphoning problems with a taildragger. Are you gonna fix it? I would. Oh, if you can, would you correct the subject to 'Saito'? http://www.rcuniverse.com/forum/js/f...wink_smile.gif</p> |
RE: Satio Question
For those who have never had the UCD. The tank is going to be high no matter. Even with the floor hacked/removed it's just the way it's built.
RE: Satio Question
ORIGINAL: daveopam For those who have never had the UCD. The tank is going to be high no matter. Even with the floor hacked/removed it's just the way it's built. Just food for thought.;) |
RE: Satio Question
When I had my u-can-do, I looped my carb fuel tubing up and over the engine mount beam then to the carb. The loop is near the top of the fuel level and stopped the siphoning.
RE: Satio Question
Yup.
I have a couple of UCD's ( including the old discontinued Giant Scale one ) that I run with inverted glow. One runs with a Saito 1.00 with no modifications what-so-ever, including no loop ( which is not a bad idea ). The Saito comes set up with an almost ridiculously rich low speed setting ( and the engine still runs fine this way! ). This cause fuel to siphon either out or back into the tank fairly quickly. However once I had the LS properly set siphoning slowed down to a managable slow drip. All I have to do is keep the throttle fully closed while filling the plane or while it is sitting in the pits. Once I am ready to start it, I'll open the throttle up and crank the engine over to start WITHOUT priming. That's it. The engine runs just fine this way and siphoning is not a major issue. If anything because you are forced to get the tuning "right" to prevent siphoning, the plane tends to be very reliable and never deadstick. Check your LS tuning. Do a pinch test.... set the LS needle so that removing the glow driver causes no perceptable change in RPM's, and you'll be in the ball park. |
| All times are GMT -8. The time now is 01:48 AM. |
